Crown SC6000 very slow lovering
Hi friends !
Asking for your advices - I repaired this truck , every thing is working fine exept just for lifting down function - the speed of lewering down is very low.
According to specification it should be 0.5 m/s.
What was done : removed , inspected and cleaned SPL and SVL valves , also
Pressure Compensator Valve. The electrical signals from Access1 and Access2 were checked on SPL and SVL by oscilloscope - they are OK.
The hydraulic oil also was changed.
Please , any idea what is the problem with so slow lowering ?
Thanks for any replies.
  • Posted 6 Jul 2023 16:32
  • Modified 6 Jul 2023 16:34 by poster
  • By Slav
  • joined 23 Jun'23 - 10 messages
  • Turkmenistan
serov.tm@gmail.com
Hi friends !
During a visual inspection for the manifold was found , that the Orifice 0.38 mm was installed under SVL valve instead of it's original location - under PCL ( Pressure Compensator Valve ).
I had put ORF3 back to PCL valve and the function Lift / Lower on the truck is working perfect now.
Many thanks for your help and support !
  • Posted 15 Jul 2023 04:27
  • Modified 15 Jul 2023 15:08 by poster
  • By Slav
  • Turkmenistan
serov.tm@gmail.com
I disassembled the pressure control valve from main hydraulic cylinder - every thing is fine overthere. The valve is clear and no any debrises or dirt inside cyliner.
For now I have to remove the manifold from the truck and do a visual inspection for mentioned above valves one more time.
  • Posted 14 Jul 2023 14:59
  • By Slav
  • Turkmenistan
serov.tm@gmail.com
Performance settings both of lift / lover - 9.
  • Posted 13 Jul 2023 14:17
  • By Slav
  • Turkmenistan
serov.tm@gmail.com
Thanks ALL for replies !
Lovering valves as per hydraulics diagram are SPL ( proportional valve ) , SVL ( normal electrical valve ) and PCL ( pressure compensated valve or hydraulic latch as I correct thinking ).
Both of them I removed from manifold and checked physically and also by 24 and 36 VDC correspondently on the lab bench - they are OK.
Using Analizer I checked lift / lower POT4 : 0.6V - 4.1V - 7.7V , it also good.
I did a C4 calibration for lifting / lower - the system accepted that calibration.
Today I'm going to remove the pressure control valve from main hydraulic cylinder to see , if it contaminanted or not.
The truck was fully operational after I did repair but after a few days this issue with so slow lowering happened.
Thank you once again.
  • Posted 13 Jul 2023 14:13
  • Modified 16 Jul 2023 01:56 by poster
  • By Slav
  • Turkmenistan
serov.tm@gmail.com
I know that the lowering valves will cause a slow lower on the SC5200s. Not sure if the SC6000s have them as well. If so it might be worth checking. If not, disregard.
  • Posted 12 Jul 2023 05:01
  • By marcos_m
  • joined 25 Feb'19 - 114 messages
Have you tried recalibrating the lowering valve? Go to settings, calibration, 2.1 (if I'm remembering correctly). Then then Lift will automatically set the lowering speed to the proper speed.
Otherwise it may have been set in the performance settings as you can change the speed of lifting and lowering in the performance settings.
  • Posted 11 Jul 2023 23:59
  • Modified 12 Jul 2023 00:01 by poster
  • By DyslexicNerd_01
  • Wisconsin, United States
JCB 533-105
Mitsubishi FGE35AT
JCB 533-105
Mitsubishi FGE35AT
