Crown RC 3000 s/n 1A229411 Plugging issue
EV100LX
I have eliminated the SCR panel by installing it into another unit and testing it worked great. I disconnected the 1A contacter and at full SCR or 1A the unit plugs hard, comes to a stop real quick. It plugs fine at slower speeds it just seems to be at high speed. The speed pot checks out great, as I said the SCR panel is fine, it has also been pulled apart and every component checked plus put on the sister unit. Drive motor brushes have been checked, static strap is ok, cables are not shorting out anywhere that I can see or checked with a meter. The EV100 card has even been tested on the other unit.
Please email me with your thoughts.
Thanks
gamingdd at ****.net
  • Posted 9 Nov 2011 04:53
  • By VXman
  • joined 14 May'09 - 34 messages
  • Oklahoma, United States
It was checked earlier, we found the tips in the contactor bad
  • Posted 14 Nov 2011 14:57
  • By VXman
the rec wath i mean is not in the rec panel, is in the contactor panel, behind the but of the operator.
sometimes we forgot this one. maybe you check it, may be not.
best regards
  • Posted 14 Nov 2011 13:51
  • By raul_s
  • joined 17 Jun'10 - 134 messages
  • San Luis Potosi, Mexico
Thanks, found the d contactor tips bad
  • Posted 11 Nov 2011 10:05
  • By VXman
it may be the "d" contactor. The smallest and lowest on the contactor panel. It may appear ok but a swap may prove it faulty
  • Posted 10 Nov 2011 12:33
  • By cheek
  • joined 6 Nov'09 - 25 messages
  • Alberta, Canada
hard plug problem? replace the dual motor contatcor assy.
Bet ya a lunch that will fix it.
  • Posted 9 Nov 2011 21:46
  • By richard_c
  • joined 17 Aug'09 - 14 messages
I know the recs are not the problem because we used a different panel from another unit and install the panel from this unit in another lift and it worked perfect.
I will disconnect one motor at a time tomorrow are see if there is some kind of motor issue.
Thanks
  • Posted 9 Nov 2011 14:05
  • By VXman
No, the hyd. system not cause that.
but if you disconect one motor and work with the other, and after
do the same with the other motor.
only for check it, if one of the two motors have a trouble in the inner, on one of the two motors or in both.
other cause may be is the rec in the contactor panel.
  • Posted 9 Nov 2011 13:35
  • By raul_s
Will that cause plugging issue?
  • Posted 9 Nov 2011 08:23
  • By VXman
-93 Code on a crown is for Pump Motor brush wear indicator,check you brush's on the hydraulic pump motor
  • Posted 9 Nov 2011 08:05
  • By kevin_t
The unit has a code -93, looked at the mor and brushes don't see an issue. Not sure how the balance contactor is tied in.
  • Posted 9 Nov 2011 07:41
  • By VXman
Any Codes showing on display,if no display have you hooked up a handet to the card to see if any codes are stored there?
  • Posted 9 Nov 2011 07:37
  • By kevin_t
seems like the motors are the only thing you haven't had checked by replacement with known good parts.
  • Posted 9 Nov 2011 06:18
Kai von Berg Kai von Berg
