Creep Speed only (No Codes)
I have an RD5200S AC. Creep/limp speed (<0.5mph) only with no codes. Can anyone tell me what voltage readings I should see at the "U" "V" & "W" motor leads at full travel command. All 3 AC motor leads are pulling 300+ amps at full travel demand. I looked at this though access 1 and also confirmed it with an amp clap direct on each lead.
I have already confirmed all my command inputs (POT1 etc.) are at spec.
I'm leaning toward a failed trac mot but would like a little more info to support my theory.
Thanks!
  • Posted 22 Dec 2016 01:59
  • Modified 22 Dec 2016 02:42 by poster
  • By chevotaman
  • joined 28 Feb'14 - 112 messages
It's all just nuts n' bolts.
Yep sometimes access 3's don't throw codes
  • Posted 1 May 2022 00:51
  • By Ratm
  • joined 21 Jun'19 - 17 messages
Stoney
I've encountered this before, actually! I've noticed that sometimes my RMD or RD (RR Series) will go at a creep-only speed, but as soon as I turn the steering column enough to turn the wheel a small amount, I am given full speed control once again.
I've just shrugged it off as a quirk of my lift, and learned to deal with it.
  • Posted 5 Mar 2017 00:40
  • By Raina
  • joined 5 Mar'17 - 6 messages
  • Indiana, United States
Try calibrating the POT. And check the motor encoder input.
  • Posted 20 Jan 2017 13:18
  • By Yidneck
  • joined 20 Jan'17 - 110 messages
Dreamt I was fixing a machine, then came the paperwork and it turned into a nightmare.
Yes, RD5200S-AC
It was the Traction Mot.
  • Posted 7 Jan 2017 06:47
  • By chevotaman
What height does it think the forks are at? Also are you sure it is a 5200 and not a 5700? If 5700 it could be Access#4 module with the accelerometer.
  • Posted 27 Dec 2016 01:54
  • By popeye
UN Forklift FD25T-C2JM1
Toyota 8FD45
Libiao Robotics
Sue Tomic Sue Tomic
