crank no start
have a lift that has crank but no start replaced the regulator and is getting spark but is not starting
  • Posted 23 Nov 2022 02:38
  • By Wes7413
  • joined 23 Nov'22 - 1 message
  • Kentucky, United States
Check the following
1- The fuel run relay and fuse in the PDM (fuse box) swap the relay with an other relay. Or check for voltage at the fuel regulator lock off but this will take two people. Battery voltage is regulated so with the key on and the engine not running the battery voltage to the regulator will time out. You can also try starting fluid to see if the engine will fire off but be careful. If the engine fires off then the issue is in the fuel system if not continue with the following.
2- Check the LP mixer diaphragm. Make sure it isn't dirty, torn or hard.
3- Replace the crank sensor located at the bottom of the timing cover. The VSM must read 150 RPM before the engine will start up and run. In saying this also make sure the battery is charged and in good condition as well as the starter operating properly and not dragging.
  • Posted 30 Nov 2022 00:33
  • By Jessy_Gomez
  • joined 30 Nov'22 - 12 messages
JJG
i'm not at my computer with my manuals on it but check your oil pressure switch. if it is not sending a signal to the fuel lock off you wont get fuel
  • Posted 24 Nov 2022 07:37
  • By Nwrecchian
  • joined 18 Aug'22 - 19 messages
  • Maine, United States
Mitsubishi FD200
Airman ENCL045
Tampa Florida, United States
edition #1289 - 9 July 2026
In this week’s Forkliftaction News , we continue our coverage of CeMAT Australia with a report on how the lack of local after-sales support and service is hurting new foreign entrants into the Australian market... Continue reading
Mitsubishi FD200
Airman ENCL045
November 3-4 2026 - Houston, United States
Mitsubishi FD200
Airman ENCL045
Cameron Paxton Cameron Paxton
President and chief executive officer, Toyota Material Handling Australia (TMHA)
President, Doosan Bobcat North America
Chairman of the board of directors, Manitou Group
Sales manager for the UK & Ireland, BSL Battery
