Toyota 8FGCU15:
crank no start no spark
Have a unit that will not start off of good battery. if I hook unit to jump pack with no battery unit starts right up. starter ground, water pump grounds, and battery ground all good and clean. positives going to starter and 80/100 amp fuses all good. please help!
  • Posted 7 Aug 2021 02:12
  • Discussion started by cincylift
  • Ohio, Zimbabwe
new distributor took care of the problem.
  • Posted 17 Aug 2021 08:57
  • Reply by cincylift
  • Ohio, Zimbabwe
Iav seen the pickup wire sending too low a voltage,, run 12 volts to starter off battery to check
  • Posted 13 Aug 2021 00:07
  • Reply by DAMO
  • DUBLIN, Ireland
up up and away
with new battery when it won't start voltage drops to low 11 volts. on jump pack only when it starts it drops to 9 volts. need a wiring diagram or am thinking replace distributor?
  • Posted 11 Aug 2021 07:17
  • Ohio, Zimbabwe
ive replaced negative ground cable to frame and cleaned frame to bare metal. maybe I'm missing a ground? the unit will not start with jump pack hooked to battery and cables on unit. remove battery and only jump pack it starts. tried isolating battery from unit and still no luck.
  • Posted 10 Aug 2021 07:54
  • Ohio, Zimbabwe
watch what voltage drops to when attempting to start with the "good" battery
  • Posted 10 Aug 2021 00:56
  • Reply by Triggs
Almost every time that I have seen this it has been a bad negative cable connection on the truck frame. Also, I don't trust a simple battery voltage check. Have you done an actual load test on the battery?
  • Posted 8 Aug 2021 13:44
  • Reply by 1CrownTech
  • Washington, United States
1crowntechnician@gmail.com
edition #1228 - 1 May 2025
Linda Häkkilä Linda Häkkilä
