Condition Based Maintinence.
Just wanted to see what the consensus was on this subject. Basically, instead of downing the units and going from forktip to counter weight on a PM, Condition based Maint: is the inspection and servicing of specific components that are seeing wear within the same model type. Has anyone heard of this method?
  • Posted 8 Mar 2011 21:21
  • By chublil
  • joined 28 Jul'09 - 187 messages
Fix it right!!!
It make sense to what you are saying, as long as the same units are doing the job function every day and the service person is initmately knowledgeable of the various operations & hourly useage of each unit & is keeping records of when the "skipped' items are due; the PM frequency is in tune with the manufactures recommendation (most are backed on normal/clean and is kept in the communication loop when & if units are rotated to another job function/enviorment. As you well now, freezers units would need an increased frequency of PM as condensation & cold soaking plays havoc with everything on the units.
If you change service guys (girls) then you get to retrain again.
  • Posted 17 Mar 2011 04:45
  • By johnr_j
  • joined 3 Jun'06 - 1,445 messages
"Have An Exceptional Day!"
Let me give it in a little better detail. As you know its not the pallet but everything around the pallet that causes wear and tear. (Operators-floor condition-hydraulic cycles specific to the site-freezer app vs. dry grocery--condition of batteries etc.) If you have an in house set up where the same guy is touching the trucks, then based on the sites conditions you may cut the time spent for pm in half for certain parts of the same make or model truck, and you may extended out the pm times for other components on the same makes and model units. If you have heavy hydraulic cycles but the units are not freezer app, you could go thru all the same make units and service just the masts and attachments and leave the steer axles and traction motors until every other pm. Is this making any sense?
  • Posted 17 Mar 2011 03:54
  • By chublil
Fix it right!!!
I've never hear of that but based on the wording & brief description, it sounds like the customer would be short sheeted on key items for the sake of saving a few bucks. Key items, like fork wear, lift chain adjustments, oil/filter (they rarely fail but if not change will cause big buck failure), lube (mast pivots, steering axle, tilt pivots, foot control pivot shafts, etc.), just to name a few. It also sounds a lot like "break down" maintenance to me vs. planned (aka preventative) maintenance.
Just my opinion, but I haven't heard everything. Would be intereseted in more details of such a program for ICE & electric both.
  • Posted 17 Mar 2011 03:41
  • By johnr_j
Phytoplankton create at least half of the world's oxygen production, despite amounting to only about 1% of the global plant biomass. They also respond rapidly on a global scale to climate and environmental variations, so are often used as indicators of marine health.
October 13-15, 2026 - Shenzhen City, China
November 10-11, 2026 - Auckland, New Zealand
June 17, 2027 - Nottinghamshire, United Kingdom
ORDER PICKING
FLEET MANAGEMENT
HIGH-CAPACITY FORKLIFTS
CHARGING INFRASTRUCTURE
SAFETY SOLUTIONS
