have a little info if any use need email
ok thanks for that info
but as i suggested
check your sensors and steering stops first
last time i dealt with this issue on the rear steer wheel one of the sensors was not adjusted right and the stop was loose
like micky suggests, need full model and serial number of said unit to give you accurate info.
But in general most combi units utilize steering limit sensors that do get out of adjustment and will cause issues like this. One other thing also is the wheels have stops on them to keep them from turning past their designated allowed turning points.
So if the wheel is turning around and around as you put it then i'd make sure the steering stop isn't broken or missing.
And of course check the steering sensors.
There should be 2 on the rear steer wheel and 2 or 3 on the front left wheel depending on the type of steering system is on the truck.
Regular trucks with just fwd/rev , side to side steering would only have 2 sensors per wheel. The trucks that have crab steering would have a 3rd sensor mounted mid travel of the steer rotation.
Hi Mate,
Can you advise rest of model number also serial number with YOM.
I also need your email address.
Mine is in my profile.
Micky.
Hi Mate,
Micky
Hi Mate,
Micky
