coil wiring / firing problem
We have a mitsubishi fg35ab with a firing problem. We found that the dist. cap was jumping fire inside when the key was on, even when not being cranked. We replaced the cap but still had the same problem. We then replaced the coil/resistor (comes together) then the pickup/module in the dist. Still the same. Any ideas? Also does someone know the wiring connections for the coil? We had previously replaced the resistor with an aftermarket as we could not get it seperately. We may not hve the right wires on the right terminals now.
  • Posted 13 Apr 2010 04:51
  • By BobR
  • joined 25 Apr'09 - 7 messages
  • Kentucky, United States
If that is repeatedly firing sparks by just turning the key on, that is a bad ignitor in the distributor. The piece the pickup coil is connected to.
  • Posted 13 Apr 2010 08:48
Taylor T650L
Toyota 02-2TD20
