codes p 03 and p 07
hi guys , i have a problem with my CAT the engine started but no traction i hope that somebody can help me please
  • Posted 6 Jan 2015 13:02
  • By 80luis
  • joined 6 Jan'15 - 2 messages
  • nuevo leon, -
thanks swoop223 I've check te harness and conector and this is ok but i don't checked the EGI relays i'll try tomorow thanks so much....my best wishes from monterrey
  • Posted 7 Jan 2015 09:46
  • By 80luis
  • nuevo leon, -
P03 - VCM communication error
P07 - MP communication error
first i would check the relays in the relay box and make sure they are ok. I've found that bad relays (EGI relays) can cause communication errors.
Also check the harness between the ecm and the meter panel, the com error is between the ecm and the meter panel, make sure the connectors are plugged in and locked in.
  • Posted 6 Jan 2015 22:37
