codes a6-1,a6-3 , 63-1
Have these codes at start up.A6-1, A6-3, 63-1. No hyd function..have Changed lift and tilt switches have new harness, Cpu , hyd motor. Book says adj switches but no ajustment for tilt switch Could I have put the new tilt switches on in the wrong location as they are conected to 1 connector. Travel not affected. Also bdi flashes all segments. Battery is known good.
  • Posted 10 Feb 2013 03:17
  • Modified 11 Feb 2013 21:43 by poster
  • By stevepops
  • joined 22 Dec'12 - 10 messages
  • Oklahoma, United States
im getting a constant code 31...it used to happen here and there now it is like 90% of the time it throws this code alarm sounds and lift wont move. If any one knows what could be the possible causes that would be greatly appreciated.
  • Posted 21 Sep 2016 22:29
  • By Gator
  • joined 3 Oct'14 - 45 messages
does a toyota 6BRU18 have battery as well?
  • Posted 21 Sep 2016 22:25
  • By Gator
I believe that there is a kit so you can replace the display battery. Fixnproblems is correct that it does cause multiple false codes when that battery dies.
  • Posted 16 Feb 2013 10:09
  • By rogeriwt
I have ran into this similar problem. There is the display and under that a display card.(attached in the same white box) I have had to change the display card numerous times because there is a 3.6 volt lithium battery soldered into it that goes dead after awhile and causes multiple codes to appear. I would swap that card out with a known good one.
hopefully this helps you out.
  • Posted 14 Feb 2013 13:09
  • By fixnproblems
  • joined 19 Jan'13 - 66 messages
Crown RD572513TT6860R
Mobicon 2T
