Code T236
Ser#H2X394S03558 Code T236 No drive operation, Hydraulics work but no engine throttle control. Flywheel sensor was replaced.
  • Posted 8 Mar 2013 06:47
  • By joe_o
  • joined 12 Apr'12 - 3 messages
I am also having that fault code T236 but mine there's no drive at all so doesn't rev up but the hydraulic works,any idea please,thank you.
  • Posted 14 Oct 2016 18:29
  • By dido_e
  • joined 14 Oct'16 - 3 messages
  • Gauteng, South Africa
Sounds like it could also be chipped fly wheel tooth
  • Posted 24 May 2015 06:14
  • By edward_m
  • joined 11 May'15 - 111 messages
Hi Joe,
What clearance have you set the actual speed sensor to>>>>
should be 0.5mm up to + 0.3mm
The only way to check the function of the sensor is using motor data software on laptop.
  • Posted 13 Mar 2013 02:38
  • By micky_h
  • joined 26 May'11 - 205 messages
  • South Elmsall, United Kingdom
Yes we found hydraulic controller plug was missing. Now code of T248 speed sensor. Installed new sensor but we still have the code when engine hits Hi rev it drops in creep mode until you recycle key switch. We think it may be the ring gear teeth, hard to check inside of gear.
  • Posted 12 Mar 2013 07:10
  • By joe_o
Hi Joe,
T236 = Travel direction switch all inputs open
e.g. Coding connector missing, sounds like you have wiring issues.
Regards
Micky
  • Posted 12 Mar 2013 03:49
  • By micky_h
edition #1281 - 14 May 2026
UN Forklift FB25N1LZ1
Still GX10
Still GX10 2000
Poland
EUR950
