Code T231
S/N HRX391LL01699
VW motor with L/P fuel
The truck comes to a stop and there is an audible tone. Code T231 comes up on the display. Now I've figured out the code is caused by the pedals sensor having an issue. What I need to know is the location of the sensor. Is it in the pedal box and do I need to replace the whole pedal box? Or where would I find this sensor?
  • Posted 4 Mar 2025 05:03
  • By Marc_Malone
  • joined 4 Mar'25 - 4 messages
Marc Malone, RAP Lead
Ok, I will see if I can figure it out... I'm just a self taught mechanic and learning as I go. I do tend to catch on to things quickly though so I'll see if I can figure out where these things you mentioned are.
  • Posted 11 Mar 2025 02:01
  • By Marc_Malone
Check the pedal position potentiometer, calibrate to center ,if it was replaced it has to be calibrated , if not probly needs to be replaced an calibrate. Also check wiring running under pedal assy ,I've seen the harness run thru an create shorts , also check the pedal pot gear is not worn out an going out of range.
  • Posted 8 Mar 2025 03:28
  • Modified 8 Mar 2025 03:31 by poster
  • By Tim_Hamrick
  • joined 29 Apr'23 - 8 messages
  • Maryland, United States
Timothy hamrick
Senior field service technician
231 Combination of pedal position sensor signal and reference sensor signal is not plausible.
  • Posted 6 Mar 2025 16:52
  • By michel_v
  • joined 8 Mar'08 - 1,039 messages
  • noord holland, Netherlands
Cortney Hunt Cortney Hunt
COO, Intelligrated, Trew and Transnorm
Automation manager, N.C. Nielsen
September 29-01 October, 2026 - Cairo, Egypt
October 6-7, 2026 - London, United Kingdom
