Code L222
I have a lift that has a code L222 that comes up on the dash along with a lightening bolt and flashing wrench light. When you cycle the key off and back on it goes off, but will come back. The customer says you can hit the dash and it will go off, although we can't duplicate this. Does anyone know what this is?
  • Posted 7 Sep 2013 02:19
  • By forkliftmgr
  • joined 7 Sep'13 - 2 messages
Gud day sir i want to ask if the error of your l232 been remove and how did u do it pls help have also problem with L232 tnx in advance
  • Posted 29 Nov 2018 02:05
  • By chadaw_isidro
  • joined 12 Sep'18 - 21 messages
  • Saudi Arabia
Hi, I am having trouble withe theses machine H50D. I have replaced joystick and code still persists. I have linde pathfinder but I'm not luck in calibrating this joystick. I only have tilt forward and back when AUX plugs disconnected. Am I connecting the laptop cables up correctly? Codes L232, L233, L238 and L222 as soon as key switch on. Thanks
  • Posted 7 Sep 2017 03:29
  • By Juanes
  • joined 27 Mar'17 - 10 messages
  • Bucks, United Kingdom
micky, I have replaced joy sticks, because of code and also joystick has no snap to it. is their a fix for this?
  • Posted 22 May 2015 11:40
  • By edward_m
  • joined 11 May'15 - 111 messages
I would hook up the truck to Pathfinder and do the Joystick calibration and clear the fault codes.
You can also check the joysticks for being in a neutral position by going into joystick parameters in Pathfinder.
So many people replace joysticks when there is no need to.
  • Posted 10 Sep 2013 01:06
  • By micky_h
  • joined 26 May'11 - 204 messages
  • South Elmsall, United Kingdom
Tip for the future with Linde trucks is, post up the start of the serial number to pin point the series & year.
From the info already provided its either going to be a H2X 392 or a 393, the letter after the 3 digit series number gives the year of manufacture, year is also on the data plate.
L = a lift fault ( smart these German's )
L222 = Joystick for more than 2 sec not in neutral position after Power On.
If it has a key switch fitted, check the contacts & switch, sounds like its very briefly powering down & back up again which in turn throws the error code.
Check the hydraulic joystick's & the wiring to them would be a good place to start.
If you have the 4 way joysticks fitted also check the rubber cover with the symbols on hasn't come loose from the console as this can stop the joystick returning to neutral position.
  • Posted 7 Sep 2013 02:46
  • Modified 7 Sep 2013 02:48 by poster
  • By Forkingabout
  • england, United Kingdom
Neptune was discovered in 1846. It then took 165 years, or until 2011, for the planet to complete one orbit of the sun.
Hawker Powersource, Inc.
ORDER PICKING
FLEET MANAGEMENT
HIGH-CAPACITY FORKLIFTS
CHARGING INFRASTRUCTURE
SAFETY SOLUTIONS
ORDER PICKING
FLEET MANAGEMENT
SAFETY SOLUTIONS
