Raymond EASI REACH:
Code I07
can someone tell me what this code petains to. Unit will not move just beeps
  • Posted 26 Jan 2012 10:08
  • Discussion started by jerry_c
You are in active maintenance mode. This is not a trouble code. It's an input parameter that you can command on while the truck drives normally. Someone selected this feature and turned it on either by accident or for testing the reach "out" switch on the control handle. If you depress the retract button you should see i 07"in" if the display does not change then you have a bad vehicle manager. That may be why the "Input 07" is on the display. If the truck is running fine just leave it. If it reaches in and out then the switch is ok. you can try to clear the test in active maint. Do you have the superword to access the maint mode?
  • Posted 2 Feb 2012 21:22
  • Modified 3 Feb 2012 07:28 by poster
  • Reply by EasiTek
the unit is an easi reach truck. the code that comes up is i07 out.
  • Posted 1 Feb 2012 03:12
  • Reply by jerry_c
I'm sorry, is that i 07 or 107 (one o seven)
And what model. EZ A, EZ C? You may be showing "Input 07"
As there is no code 107 on a reach......
  • Posted 31 Jan 2012 12:19
  • Reply by EasiTek
Thank You Ray. Our code that comes up is I07. Is that the same as e107?
  • Posted 31 Jan 2012 10:10
  • Reply by jerry_c
There is many posts further back on E107. #1 cause is dirty contactor tips. #2 cause is Main fuse burned from overloading. Check main fuse, if ok replace tips. Cleaning them works somtimes
  • Posted 29 Jan 2012 23:43
  • Reply by EasiTek
Ottumwa, IA, United States
Wentzville, MO, United States
Harrisburg, SD, United States
ROYPOW
edition #1235 - 19 June 2025
