Code F3
Can some one help me with code F3?
  • Posted 3 Jul 2014 00:33
  • By ChrisD
  • joined 1 Mar'12 - 21 messages
  • Kentucky, United States
Thanks for the Help, Best Regards
  • Posted 17 Aug 2021 23:44
  • By MM2952
  • joined 30 Jan'16 - 10 messages
M. Moreno
F3 is a pump system failure.
most likely cause is a pump transistor T1P or T2P failure.
Now in the possible causes section of the problem diagnosis section it gives more detailed explanations:
"Shorted T1P, T2P (T3P if equipped); Open wiring; Driver board defect; Logics defect; Open circuit pump motor or PA1, PS2 cables; Welded pump contactor (if equipped). Shorted Z321 or Z322 (if equipped)."
you will need the diagram schematic that is usually located underneath the hood that has the diagram of the electrical system with labeled components and a condensed troubleshooting and onboard self check chart for self diagnosis and/or the service 'troubleshooting' section of the manual, some tools to remove the components for testing and a vom meter, (and a handyman tester if you need to gate or leak test any transistors).
In most cases these issues wind up being a bad T1P or T2P transistor or a welded contactor (if equipped). The transistors should be disconnected before checking.
  • Posted 17 Aug 2021 21:33
Hi Chris
Did You get any suggestions on this code F3?
Please let me know. Thanks
  • Posted 17 Aug 2021 01:57
  • By MM2952
M. Moreno
Toyota 8FG25
Mobicon 2T
Lift Technologies Inc.
Toyota 8FG25
Mobicon 2T
