Hello,
First time, sorry for my english. I need information regarding an error code E62.
I would like to know the potential causes.
On the doc I only have this : The two microprocessors receive different signals.
I tank you, for your help.
Good morning,
I replaced the traction variator.
Model FZ2007
The fault code has just reappeared.
Do you think the problem comes from a parameter?
thank you for your response
Good morning,
Thank you for your answers I will look into this today. And order a controller.
Hi error code e62 is the control needs to be replace, contorl has internal short
good luck,
If you do a search for the zapi eps controller you can find a manual for free.
If you have a zapi handheld you can connect it to the EPS box.
Also there should be a possibillity to enter the dashboard with a code.
