Code ED
Hi Folks,
I was blocking and chaining the mast for a hyd hose replacement.
Code Ed showed up.
It will not clear with a key recycle. Operator states it`s been doing that
off and on for a while, always cleared with a key recycle.
Inspected connectors and tested wire harness between display and VM,
No opens or shorts, terminals look OK.
This one is 2GL01577, they have another, 2GL01744.
I`d like to swap parts but the Service Manual note says replacing the
display requires special procedures, contact Material Handling Associates.
Can I swap the display or VM for diagnostics without causing issues?
Thank you
Ed
  • Posted 30 Aug 2020 00:53
  • By Ed_WI_USA
  • joined 30 Apr'10 - 2 messages
  • Wisconsin, United States
Combilift Ltd
