Code E159 Fixed
Hi, I'm new here and thanks for accepting me.
"Disclaimer I'm not a certified TMH technician, so do this at you own risk"
Fyi- I end up replacing the Key pad also, as the ribbon cable is very fragile so B-careful ;).
Here is a little contribution to this problem
How I was able to fix the E159 code on the E-pallets jack was, By checking (I did All the other stuff that the manual recommends too) also The 3v coin battery on the ETAC CARD witch it was 0, so I replaced that and problem solved no more E159... Hope this help someone
  • Posted 12 Feb 2022 08:04
  • Modified 15 Feb 2022 01:27 by poster
  • By Victor_MG
  • joined 12 Feb'22 - 2 messages
Hi Victor,
Do I need to reprogram keypad if I change the coin battery? I attempted it. Everything seems fine but the keypad seems unresponsive. 1 and green button code doesnt work anymore.
  • Posted 14 Feb 2025 04:50
  • By V_LER
  • joined 14 Feb'25 - 1 message
ETAC detected problem with the CAN-bus.
Possible Cause with
Corrective
Actions/Checks:
1. Short or open circuit in CAN-bus wiring.
2. Electrical noise in CAN-bus wiring caused by bad connection, outside
interference, or low voltage:
a. Check CAN-bus wiring.
b. Try driving using a known-good battery.
c. Try driving in a different environment.
3. Faulty power amplifier. Check power amplifier.
4. Faulty ETAC.
  • Posted 18 Feb 2022 15:49
  • By delga76
  • joined 20 Oct'16 - 22 messages
thanks
edition #1303 - 15 October 2026
In this week’s Forkliftaction News , we report on a number of product launches including an Auto-Navigation Forklift Robot from Chinese equipment maker Leapting, developed for utility-scale solar construction sites... Continue reading
The term 'Genuine Leather' is not used to reassure you that the product is made of leather, but rather to indicate that the lowest quality of leather is used.
UN Forklift FBT20NQZ1
Ncn 110TH
Ncn 110TH 2015
