Code C26
Book is vague, hyd lever potentiometer I'm only aware on a potentiometer on the drive motor (steering). Any helpful information appreciated.
  • Posted 13 Jan 2024 05:56
  • By BJB64
  • joined 21 Apr'23 - 3 messages
  • Tennessee, United States
BJB
Input value from lift pot in control handle fault.
One (or more) out of three things.
Analog 1 and 2 correlation greater than 0.625v
Analog 1 or 2 input value less than 0.25v
Analog 1 or 2 input value is greater than 4.75v.
You can see the input value on the display if you want but you need to be fimiliar with and able to read hexadecimal. Best to back probe the wiring at the pot on the handle to confirm voltages then confirm voltage readings at the traction/hydraulic card.
  • Posted 13 Jan 2024 10:28
  • By BLey
  • joined 31 Jul'20 - 60 messages
Neptune was discovered in 1846. It then took 165 years, or until 2011, for the planet to complete one orbit of the sun.
