Code 92-1
Looking for troubleshooting suggestions for a propane Yale, model GLC050VXNDAE083. Truck will randomly throw a code 92-1 on the display and the service engine fault light comes on. When this happens there is no response from the throttle. Normally, restarting the engine will correct the issue. This might happen once an hour or once a week. I am currently trying to find a parts/service manual for this truck, but we bought it used so I dont even have access to the menus. Does anyone have any suggestions on what I can check while I am waiting to find a manual. I appreciate it.
  • Posted 12 Feb 2019 23:36
  • By GaryT
  • joined 28 Apr'11 - 10 messages
Ramon,
Start the engine and press the throttle pedal down and push on it sideways. If code shows, bushings inside pedal assy are worn and need replacing. You will need to install a new pedal and mount. Verify all connections and wiring has not chaffed. Good Luck
  • Posted 2 Jun 2023 02:22
  • By garland_m
  • joined 16 Oct'09 - 224 messages
  • Virginia, United States
Work Hard and Fish Long
Hey gary did u ever figure out the problem. I have one with the same problem 91-2 so intermittent.
  • Posted 1 Jun 2023 07:54
  • By Ramin_Barai
  • joined 13 Nov'22 - 3 messages
Thank you, the operator had the numbers reversed on the sign-out sheet. Is this a remove and replace procedure or will the new sensor need to be calibrated?
  • Posted 13 Feb 2019 01:45
  • By GaryT
There is not a code 92-1, there is a 91-2 code. It sounds like your pedal position sensor is about to fail.
  • Posted 13 Feb 2019 00:09
  • By BREWSKI
edition #1267 - 5 February 2026
In this week’s Forkliftaction News , we report on the January Logistics Managers' Index - a bellwether of the US logistics sector - which has jumped 5.4 points in a month, below the all-time average but still indicative of consistent growth... Continue reading
Alexandre Guiard Alexandre Guiard
SVP business solutions for the Americas, Dematic
Director of marketing, Big Joe Forklifts
Managing director , Heli Canada
Chair of the board, LEEA (Lifting Equipment Engineers Association)
Taylor TT300
USD98,500
Linde C4230TL5
