code 8l and 4c
I get code 8L and 4C on my truck. sometimes its just 8L as soon as I turn it on and sometimes its that and 4c as soon as I hit the pedal. I have already replaced the dead man switch and cleaned everything up. sometimes it'll go hours without doing it and then it'll do it non stop. any suggestions? if I turn it on and don't touch anything for about 2 minutes 8L will also pop up if it already hasn't
  • Posted 27 Oct 2016 06:31
  • By DanMc
  • joined 8 Jun'16 - 80 messages
Hi yes is truly the wire from brake coil was broken 8l pup up.. and revolves the code
  • Posted 13 Sep 2023 04:13
  • By armando_g
  • joined 11 May'18 - 48 messages
grgarryciencia@aol.com
Look real close at the board female terminals where the relays plug in. Have all relays out, compare each set of female terminals to the others. One set even slightly spread apart, will cause you all kinds of headaches
8L with 4C is always caused by burned relay terminals. Adding just a new relay helps for a bit, then, it fails again
8L by itself is broken wire at brake #1 cause, then relay bad, or pin at VM is burned. You can save the VM by simply jumping the connection from the harness into the VM...Save a lot of mula!
  • Posted 14 Dec 2016 14:09
  • By EasiTek
Ended up being the k2 relay I replaced was also bad. Sent me in circles because I believed that since I replaced it and the board looked good my problem was elsewhere.
  • Posted 28 Oct 2016 04:28
  • By DanMc
even if I unplug the switch and leave it open it still gets the 8lwhen I turn it on and stay off the pedal
  • Posted 28 Oct 2016 00:22
  • By DanMc
wires to dead man switch go open, short harness
check previous 7400 posts
  • Posted 27 Oct 2016 11:29
  • By EasiTek
Aichi RX07B
Toyota 3FD100
edition #1303 - 15 October 2026
In this week’s Forkliftaction News , we report on a number of product launches including an Auto-Navigation Forklift Robot from Chinese equipment maker Leapting, developed for utility-scale solar construction sites... Continue reading
Tommi Haavisto Tommi Haavisto
Director of sales, EMEA & APAC, Hiab and MOFFETT Truck Mounted Forklifts
Regional director for UK & Ireland, TVH
President - business area port solutions, Konecranes
President, Logisnext Europe
