code 72-4 and sometimes PM? appears
Hi when switch on truck no codes are shown turn steering wheel and 72-4 shows on display, also pm? what does this mean i tested the battery in the display and it shows good also i checked the pump motor temp sensor reads 560 ohms, the machine seems to operate ok but what do these messages mean. Thanks
  • Posted 18 May 2025 03:57
  • By stephen_dwyer
  • joined 14 Jun'22 - 12 messages
still learning
Thanks for reply this machine is a 3 wheeler and has i pot type sensor on top of rear steering center not sure if its this sensor or the one at near directional switch is causing the 72-4 code, any idea what the pm? means is it a preventive maintenance message if so how to reset it. Thanks
  • Posted 22 May 2025 07:34
  • By stephen_dwyer
still learning
Steering angle sensor: Open cicuit
The one at the right backwheel.
You can check in the display the Analyzer menu; monitor 4.
The signal should go up or down smoothly.
Somethimes your steer is not in line, the **** should be at 7 o'clock
  • Posted 19 May 2025 04:33
  • By John50
  • joined 7 Sep'19 - 155 messages
  • Netherlands
REPOWERTEK Inc
Hangcha CBD15
China
USD1,600
Still GX10
Still GX10 2000
Poland
EUR950
October 12-15, 2026 - Detroit, MI, United States
Ancient Egyptian civilization lasted for so long - over 3,000 years - that by the time of the New Kingdom (c. 1550-1070 BCE) Ancient Egyptian archaeology was a career option.
