Code 60
Have an intermittent problem.... have no travel, no lift - display flashes Code 60- Back up alarm stays on in Neutral or Forward. Wait a few minutes and runs fine. Any ideas?
  • Posted 20 Feb 2016 04:05
  • By joe_g
  • joined 15 Sep'07 - 10 messages
  • New Jersey, United States
Thanks for the info.
Can you please provide more details regarding the transistors you have replaced?
Are you refering to the IGBT power transistors located in the bottom of the panel?
Transistors in the H-bridge board?
Please advise
Thanks in advance
  • Posted 15 Feb 2017 07:57
  • By pirucho
  • joined 3 Sep'15 - 7 messages
  • Illinois, United States
pirucho
Code 60- what we've found is the 2 transistors were bad, replace both of them and its working fine.
  • Posted 15 Feb 2017 05:53
  • By al_c
  • joined 6 Jul'16 - 5 messages
  • Alberta, Canada
Subject - Code 60 troubleshooting procedures
Cause - You have a Code 60 intermittently and the troubleshooting has not provided a solution.
New information found for troubleshooting code 60 that indicates a connection issue at pin 73 on the processor chip. This is a board socket solder connection and not a field repair.
Resolution - Check the pins of the logic card HC-11 processor.
Replace logic card with a reman as needed as all pin connections at the processor are check by our reman vender.
PN
97C5230100 Logic unit
RM00000090 Reman Logic unit
  • Posted 15 Feb 2017 05:44
  • By milan_m
  • joined 18 Dec'09 - 15 messages
My Email - mmesic@toromont.com
I have the same issue with a Mitsubishi FB16KT
Error 60 in dash continuously
Backup light and buzzer on continuously in forward or reverse
I changed the logic card gained traction and hydraulics but still showing error 60 and light flashing
Please advise
  • Posted 13 Feb 2017 06:41
  • By pirucho
pirucho
Hi Joe, I have the similar problem right now. Did you resolve your "Code 60" issue? If you did, can you share with me?
  • Posted 6 Jul 2016 02:08
  • By al_c
  • Alberta, Canada
