Code 573 ,574,557
Hi I'm working on a stock picker that comes up with these event codes 573 comes up first, the unit stops randomly and the display reads lower lift height, but the platform is just off the ground
Any information would be much appreciated ,as I don't have these event codes in my service manual.
  • Posted 23 Sep 2015 21:00
  • By Spud1
  • joined 23 Sep'15 - 1 message
  • Queensland, Australia
Have you tried recalibrating the truck? If not i'd reccommend that. 573 and 574 are very similar except 573 is for down and 574 is up. 557 is for the traction motor which has no close relation with the lift system, these are almost 2 diffrent issues. If recalibrating dosent work i would start by taking a dvom and testing the cuircuits or using the analyzer menu built into the trucks to seecwhat the truck sees. That may narrow down the issue to an electrical or component issue.
  • Posted 3 Oct 2023 01:52
  • By DyslexicNerd_01
  • Wisconsin, United States
Event Code 573-574
Access 4 Height Encoder 4 (ECR4) or Encoder 6
(ECR6) Count Error.
  • Posted 3 Oct 2023 01:29
  • Modified 3 Oct 2023 01:38 by poster
  • By LittleJon
  • joined 6 Dec'22 - 22 messages
  • Arkansas, United States
Did you find what's wrong with the code 573? I have the same problem.
  • Posted 11 Feb 2022 08:19
  • By Wilson_Martinez
  • joined 11 Feb'22 - 1 message
Ok
SMV (Konecranes) SL37-1200A
SMV (Konecranes) 16-1200B
