Code 522761-3
Have this code not sure what it is any help would be much appreciated, thanks in advance!
Serial # L177B23098F
  • Posted 7 Jan 2017 05:44
  • By JAYS
  • joined 16 Apr'16 - 26 messages
  • Iowa, United States
522761-3 is Ign voltage too high. Have you checked the battery voltage with a volt meter with the truck running? The password could be anything. Dealers are instructed to change the password from default before shipping.
  • Posted 12 May 2017 02:50
  • By BREWSKI
no he was reading the code wrong, it is still setting the 522761-3. Machine runs fine but still has this code setting. cant get into dash "password locked" message shows up when we try 55555. Any ideas on a different password?
  • Posted 12 May 2017 01:56
  • By JAYS
Have them recheck the code. I do not show any codes that start with 533
  • Posted 12 Jan 2017 06:40
  • By BREWSKI
Thanks sir!
Customer says machine is running normally has not had any issues at all, and now says that there is a code of 533761-3 setting, any idea what code that is?
  • Posted 12 Jan 2017 03:31
  • By JAYS
DTC 522761-3 - Switched Battery Voltage 2 (IGN 2) OORH. (Reading High)
Did you have a battery charger hooked up to this truck? If not check the alternator output.
A. IGN VOLTAGE SHORTED TO UNSWITCHED BATTERY SOURCE IN PDM OR PDM/VSM HARNESS
B. IGN VOLTAGE SHORTED TO UNSWITCHED BATTERY SOURCE IN PDM OUTPUT HARNESS
C. IGN VOLTAGE SHORTED TO SWITCHED BATTERY SOURCE IN PDM OR PDM/VSM HARNESS
D. IGN 2 VOLTAGE SHORTED TO BATTERY SOURCE
E. FUNCTIONAL FAILURE IN CONTROLLER
  • Posted 7 Jan 2017 08:44
  • By BREWSKI
