I need to know what cause the code 48 of Forklift Clark NPR15D.
NPR354-0527-9700FL
I appreciate all your help with this isse
buenas tardes disculpa ivan , me podrias ayudar cual fue el problema de tu forklift NFR15D , tengo uno igual con el mismo codigo
couple of things to check
fwd/rev contactor may be defective
check for welded contacts, or a sluggish operation caused by worn parts in contactor armature parts (movable parts), or a bad coil.
check for a shorted #3 Rec
check for a shorted #3 Rec snubber (23 Rec)
check for a defective oscillator card
good luck
