Toyota 6BPU:
Code 47
Working on a 6BPU15, code 47.
Carriage manager, display board and cable assy that connects the two have been replaced. Code has not cleared. Manual says those components could be the issue. Nothing left to check per the manual.
Anybody had this problem?
  • Posted 16 Jun 2020 21:53
  • Discussion started by Joebob
  • Virginia, United States
Joe Watkins
Well I have an interesting update.
The cause of the code was a shorted blue safety light lol.
  • Posted 16 Jul 2020 00:56
  • Reply by Joebob
Joe Watkins
Did you get it figured out? just curious,
  • Posted 27 Jun 2020 01:40
  • Reply by Alvino_Revilla
I was able to get in, with no change.
I didn't check that though, I will try that! My coworker has the manual and he's off this week. So I appreciate the test numbers to check!
I did test mast cables just to eliminate them, they were good.
Thank you!
  • Posted 18 Jun 2020 22:57
  • Modified 18 Jun 2020 23:00 by poster
  • Reply by Joebob
Joe Watkins
Did you get anywhere with Analyzer mode? I was looking in the manual. Maybe test 61 or 51 would help.
61- shows current software installed. (includes display card.)
Example
Access analyze mode
At the anl scroll to 6.
and the run to 1.
There are other test under encoder that might help.
Good luck
  • Posted 18 Jun 2020 04:50
Thanks, I'll give that a try.
  • Posted 17 Jun 2020 03:14
  • Reply by Joebob
Joe Watkins
I would try Analyzer mode. The tuning mode portion also allows communication to Power Amp. See if you can do a factory default. or change parameters.
  • Posted 17 Jun 2020 01:33
Lift Technologies Inc.
edition #1228 - 1 May 2025
