code 41
unit giving code 41. anyone have any tech info to share ? serial # A4EC221417 controller # 16a71-00050
  • Posted 19 Mar 2015 06:20
  • Modified 28 Mar 2015 01:45 by poster
  • By keith_m
  • joined 29 Jun'09 - 57 messages
keith@kmcequipment.com
Hello please I have issue with this code to Cat E5000 serial number A4EC240922 code 41 and code E2 we change the pump inverter, traction inverter DSP cards the contactors and the logic card to solve codes 65 and 45 but now code 41 and code E2 has remain I have check the pump motor temp sensor and serviced the motor all look good, also the brush less steer motor looks good but I have doubt with the ESD filter also the PTC current limiter is not at the contactor and I can't find those parts please can you assist me what type of limiter you suggest and also the ESD filter, or where can I buy it thanks
  • Posted 27 Jul 2017 22:01
  • By joc167
  • joined 22 Feb'15 - 4 messages
  • Aruba, Aruba
did you ever find problem i have code 41 issue and need info thanks dan
  • Posted 16 Oct 2015 07:40
  • By liftmonkey
  • joined 16 Oct'15 - 4 messages
ok i just got unit to my shop. we changed power steering contactor,line contactor and filter on the line contactor. still gives code.(41) i pulled floor plate and yes the filter is in beteween terminals.i took it a step further and ohmed it out. shows to be open. gonna order another one.# on the board is 1002048-C the motor # is 97L20-00050. it has 2 led lights. when you look down at motor and it has a red light showing. unit will code. green light shows then it will run with no code. just wanted to mention that.
  • Posted 5 May 2015 00:18
  • By keith_m
keith,
if it is an older first generation E5000 then see if it has a sevcon motor for the steering motor, if it does then what shovel is saying might be the case, the HPK document i'm looking at deals with that type of motor and says the ESD filter is the problem and it is right at the terminals on the motor.
The PTC filter i speak of in the other HPK document is supposed to reduce or eliminate the error 41 by acting as a current limiter to prevent the over current situation that is triggering the code.
Now i'm sure if you just replace the motor assembly complete that will stop the error for a while but i can bet you after the motor gets some hours on it that it will most likely return.
If those filters are not installed on the truck at the motor and the contactor they should be.
  • Posted 3 Apr 2015 03:46
let me check this units steer motor. i am being told that the motor is the type with a LED LIGHT ON TOP. i will have them check to see if the ESD filter is in place. thank you for your help
  • Posted 3 Apr 2015 01:37
  • By keith_m
This code is usually not a contactor problem. There has been several technical bulletins. If the p/s relief goes above 1100 psi it will set the code. If you lift the floor pan and look at the p/s motor you will see the two cable connections that should have a ESD filter across the terminals. The p/s pump motor is my biggest code 41 problem.The brush motors were common to fail and sometimes can be repaired. The replacement motors are brushless. If you need part numbers or instructions on the technical updates just let us know.
  • Posted 2 Apr 2015 14:06
  • By shovel_fx
  • joined 11 Mar'12 - 41 messages
  • Illinois, United States
keith ygm
it has what you need to get the part and install it
the cat dealer should of been able to find this and help you but sometimes you run across those unwilling or just too lazy to do what is necessary to make customers happy unfortunately.
As for that replaced contactor if you can see if you can find out if it is an aftermarket contactor or a OEM part. If it is aftermarket replace it with an OEM part... these aftermarket parts are substandard parts and can cause more problems than they solve sometimes.
I hope this helps
good luck
  • Posted 28 Mar 2015 23:41
  • Modified 28 Mar 2015 23:43 by poster
customer is telling me they replaced the contactor a couple of moths ago. im not too sure about that. is there a part # i can get from you on the current limiter. i have contacted ny 2 local cat dealers and they have no clue what im referring to as usual. thanks, keith
  • Posted 28 Mar 2015 01:45
  • By keith_m
there is a service bulletin out on this code
has something to do with a voltage drop at the line contactor
they recommend installing a PTC (current limiter) across the contactor power terminals. If it already has one installed then it may need to be replaced or there is some issue with the contactor itself.
i remember when these trucks first came out and started throwing those codes we had issues with bad contactors, installing new tips did not work, the contactor had to be replaced as a complete unit. We also replaced the PTC at the same time.
  • Posted 19 Mar 2015 22:23
March 18-19, 2026 - Birmingham, United Kingdom
In the 13th century, the word "nice" had a negative connotation, meaning "ignorant" or "foolish". It is thought that the word gradually obtained a positive meaning in the English language where it was often used to refer to a person who was ludicrously over-dressed. The term was confused with a reference to something refined or someone who was "nicely" dressed.
