Code # 41
Code #41 overtemp error. I am getting this on a truck that is not hot. Maybe one hour off of a charge and this code appears.
Where is the temp sensor on this unit?
  • Posted 4 May 2009 23:11
  • By Davie
  • joined 5 Dec'08 - 26 messages
its the temp sensor on the heat sink...black and grey wires i think. some times its the plug at the ev100 card or could be the sensor.i have soldered in a 300 ohm resistor between the black and grey wires...no more codes
  • Posted 7 May 2009 10:38
  • Modified 7 May 2009 10:42 by poster
  • By raymondguy
  • joined 10 Aug'07 - 6 messages
  • Alberta, Canada
To expand on the last response:
The graphite/copper dust from the commutators gets inside the plugs and conducts enough current to make the system think that the motor is over temp.
The same problem exists for the brush-wear wiring
  • Posted 7 May 2009 06:26
  • By mike_n
  • Alberta, Canada
If the motor checks out fine, ( and this is not the proper fix ) remove the temp wires and tape them off
  • Posted 5 May 2009 09:29
  • By Jan_Haayer
  • joined 4 Mar'09 - 18 messages
  • Nova Scotia, Canada
temp sensors are inside the motors. check that the airways are clear.front band on the drive motors get blocked with crap nd roast the motor very quickly
  • Posted 5 May 2009 00:36
  • By kevin_k
September 9-11, 2026 - Hanoie, Vietnam
September 16-17, 2026 - London, United Kingdom
