Code 3701-0
What steps should be taken to repair this code. Is there a regen function for this unit to clear the exhaust filter? The unit is a yale GDP080VX fault code 3701-0
  • Posted 18 Dec 2015 06:03
  • Modified 18 Dec 2015 06:05 by poster
  • By shane_t
  • joined 18 Dec'15 - 13 messages
hyster p c service tool can do the job.....thanks
  • Posted 14 Mar 2023 06:29
  • By northstar
  • joined 16 Jun'17 - 92 messages
  • accra, Ghana
  • Posted 14 Mar 2023 06:13
  • By northstar
  • accra, Ghana
Thanks for the good advice.
DPF (Diesel Particulate Filter) has already been cleaned.
I am struggling to find out which PC scanning tool is effective.
Do you have any recommendations for scanning tools?
  • Posted 13 Mar 2023 09:06
  • By TenTen
  • joined 23 Sep'22 - 7 messages
  • Japan
its just simple i work on those machines here in ghana...just remove the particulate filter at the back....get it out and dismantle it...wash the trapped soot out with water...dry it and assembly it and mount it back.....then you will have to clear the error code 3701 and reset the dpf with pc tool and get your machine running on full throttle..i am a hyster train technician...... good day
  • Posted 12 Mar 2023 21:10
  • By northstar
  • accra, Ghana
Good day,
I am struggling with the same glitches as you.
I see from your forum that it hasn't been resolved, but have you made any progress since then?
https://www.forkliftaction.com/forum/code-3701-0-excessive-particulate-matter-level-5.aspx?t=32940
thank you.
  • Posted 11 Mar 2023 16:16
  • By TenTen
  • Japan
IF I REPLACE THE ECM DOES IT HAVE TO BE REPROGRAMMED.
THANKS VINCE D
  • Posted 3 Dec 2020 05:55
  • By vince_denisi
  • joined 3 Dec'20 - 1 message
  • New Jersey, United States
VINCE D
If you replace the catalyst, you will need some one with Yale access to reset the system.
  • Posted 13 Dec 2017 04:07
  • By BREWSKI
Good morning... What is the replacement procedure, do i need a scanner to perform this repair ? Thanks Jon
  • Posted 13 Dec 2017 02:45
  • By fretburner
  • joined 13 Dec'17 - 1 message
Thanks for the help.
  • Posted 23 Dec 2015 04:58
  • By shane_t
At this time there are no procedures you can do to fix this. You will have to replace the unit.
  • Posted 23 Dec 2015 04:24
  • By BREWSKI
Where can i find regen procedure on internet.
  • Posted 22 Dec 2015 01:46
  • By shane_t
This is level 5. Level 5 means the filter must be replaced. Customer should have parked unit and allowed regeneration, long before this came up.
  • Posted 22 Dec 2015 00:34
  • By BREWSKI
Big Joe PDR30-154
USD7,500
Ncn 110TH
Ncn 110TH 2015
