Code:3701-0 Excessive Particulate Matter Level-5
Good day,
Operator mistakenly filled diesel into the DEF tank and received a trouble code.
The DPF itself has been removed and cleaned with water.
The 3701-15 was cleared with on-board equipment, but the 3701-0 requires the "Hyster pc service tool".
The engine is running at 1200 rpm (limp mode) because code 3701-0 is displayed.
The engine rpm only goes up to 12.00 rpm (limp mode).
I am planning to purchase the "Hyster pc Service Tool" or an alternative generic scan tool, can you recommend a good scan tool?
Compatible Vehicle : Hyster
Model : H155FT
Serial No : L006V02026R
Year : 2017
Engine : KUBOTA 3.8L
Display of vehicle DTC(Diagnosis Trouble Code) and data acquisition.
Clear DTC:3701-0
  • Posted 23 Sep 2022 11:13
  • By TenTen
  • joined 23 Sep'22 - 7 messages
  • Japan
Thank you, I have already got the PC Scan Tool software.
  • Posted 20 Aug 2025 07:32
  • By TenTen
  • Japan
If you need we have Yale Hyster PC Service Tool 5.5
  • Posted 19 Aug 2025 21:01
  • By Dil_Era
  • joined 30 Jun'25 - 41 messages
helmermcglynn6@gmail.com
Yes, it's resolved.
I finally connected the Hyster PC Scan Tool and cleared the code.
As a result, the forklift is operating smoothly.
  • Posted 25 Sep 2023 16:58
  • By TenTen
  • Japan
pls have you been able to solve your problem ?
  • Posted 8 Apr 2023 00:46
  • By northstar
  • joined 16 Jun'17 - 92 messages
  • accra, Ghana
Yes, it is equipped with a Kubota engine.
The Kubota dealer at my location (Japan) refused to respond.
I am struggling because there is no Hyster dealer in Japan.
I will try to contact Hyster dealer in the US.
I am hoping to be able to clear the code by mailing the ECM only.
Thank you.
  • Posted 11 Mar 2023 13:28
  • By TenTen
  • Japan
That was a long shot I know. Because it is a Kubota engine, you are correct. The dealer will need to connect. Should you find a Cummins engine in a lift, the on-site program from Cummins can be used. Good Luck
  • Posted 11 Mar 2023 07:31
  • By garland_m
  • joined 16 Oct'09 - 225 messages
  • Virginia, United States
Work Hard and Fish Long
I tried clearing the codes by way of removing the battery terminals but could not erase the codes.
They need to be erased by a Hyster dealer using a PC service tool.
  • Posted 10 Mar 2023 16:01
  • By TenTen
  • Japan
Try this to clear code long enough to initiate DEF regen. Disconnect the positive cable and touch it to a ground. This should may clear all codes so that a regen is possible. Read through the operators manual so you know how to complete a parked regen. Good luck
  • Posted 1 Oct 2022 00:21
  • By garland_m
there is no tool or scan tool you can buy to connect into the hyster or yale service tools they are a dealer only item.
  • Posted 29 Sep 2022 01:49
  • By Nwrecchian
  • joined 18 Aug'22 - 19 messages
  • Maine, United States
Cortney Hunt Cortney Hunt
COO, Intelligrated, Trew and Transnorm
Automation manager, N.C. Nielsen
September 29-01 October, 2026 - Cairo, Egypt
October 6-7, 2026 - London, United Kingdom
ORDER PICKING
FLEET MANAGEMENT
HIGH-CAPACITY FORKLIFTS
CHARGING INFRASTRUCTURE
SAFETY SOLUTIONS
Hawker Powersource, Inc.
Neptune was discovered in 1846. It then took 165 years, or until 2011, for the planet to complete one orbit of the sun.
