Toyota 6BPU:
Code 36
Need info in a code 36.
Thanks
  • Posted 1 Sep 2022 22:38
  • Discussion started by Joebob
  • Virginia, United States
Joe Watkins
Says the lift pot is out of range. You may want to re-calibrate it before replacement.
Calibration is easy.
Primary password:
1. Press the power control and hour meter
select switches simultaneously (system
should respond with a short beep).
2. Within 10 seconds, press the UP arrow
(system should respond with a short beep).
3. Within 10 seconds, press the DOWN arrow
4. Within 10 seconds, press the UP and
DOWN arrows simultaneously and hold
them for 2 seconds (system should respond
with a short beep after 2 seconds).
Secondary password:
1. Enter the primary password.
2. Within 10 seconds, press the DOWN arrow
switch (system should respond with a short
beep).
3. Within 10 seconds, press the hour meter
select switch and the power control select
switches simultaneously (system should
"Calibrte" will appear on the display indicating
acceptance of the secondary password.
  • Posted 1 Sep 2022 22:57
  • Reply by ErichO
  • Washington, United States
Linda Häkkilä Linda Häkkilä
Dubuque, IA, United States
Louisville, KY, United States
