Code 26
I have a code 26 as soon as turn on the unit goes into selftest but it just stay in selftest and in the vehicle manager display shoy code 26 i ran all the tests and all passed except for the O20 which is ramp i swapped the HCm and PWB from another unit and its doing the same thing, i checked all the fuses, cables and short to frames and everything its good.
I really need help with this, thank you
  • Posted 29 Oct 2010 03:02
  • By LAFS
  • joined 27 Jul'08 - 4 messages
Thank you guys i did replace the fuse, and we found a broken cable from TP4 to the FWB broken that was the problem, the unit its up and running.
THANKS A LOT
  • Posted 30 Oct 2010 00:38
  • By LAFS
And if it is blown, make sure you put a 15 amp slow blow back in. You can also easily check the fuse and line filter by flipping the brake switch. If it clicks the brake on and off then both are good.
  • Posted 29 Oct 2010 21:53
  • By joe_d
  • joined 25 May'10 - 253 messages
Ain't nothing I can't fix but a broken heart and the break of day!
Check the slowblow fuse in the line filter.
  • Posted 29 Oct 2010 10:31
  • By steponmebbbboom
GemOne
