Raymond EASI REACH:
Code 26
Need some info code #26 unit will not move or lift horn is the only thing that will work.
  • Posted 27 Nov 2007 07:45
  • Discussion started by Smokey
Before changing big dollar items make sure fu8 is good. It feeds battery positive power to the power card.
  • Posted 20 Oct 2018 03:52
  • Reply by tyler_d
Strangely I just had a OP30 that would code 2D then go right into 26 , changed out TM's , power card,leads after testing for shorts, etc. Thought I had it, came back, swapped motor from another OP that had been running a long time, still coded after a few days. Then I noticed that the truck was slow to start and Q1 didn't sound right even though it and Rect 1 tested good. I changed out Q1, & Rect 1 truck ran normal --for a few days. Code 26 came back, new motor and new power card finally solved it. I believe what happened was this, Q1 was not conducting pulses correctly at lower end causing the power card to pulse the field stronger to start the truck moving due to armature not responding that got the power card(maybe motor). The old motor I swapped from another OP shorted the fields when hot , took out the power card. I was chasing my tail, new motor and another power card solved it but sad case of "known good motor that wasn't" sure put a monkey wrench in the works!
  • Posted 15 Jan 2010 11:02
  • Reply by MtnMan
  • Alabama, United States
We work on anything and sometimes we fix something!
the Q1 is in the armature circuit. a 26 would lead you to the power card, open field wires or TM1 or TM2 transistors.
  • Posted 9 Jan 2009 00:37
  • Reply by E_lift
JonG thanks thats what ist was thanks for your help. have you had any experience with a CAT EP20T code 50 steering sensor I have replaced and speed sensor and main board.
  • Posted 7 Dec 2007 10:01
  • Modified 7 Dec 2007 10:05 by poster
  • Reply by Smokey
It's probably the drive motor or the cables to the motor. Code 26 is an open detected in the field circuit. It could lead to the Q1 circuit...
  • Posted 27 Nov 2007 08:22
  • Reply by JonG
  • United States
UN Forklift FBRP15NQZ2
Taylor T520M
Noblelift
Toyota 8FBE20U
Flesherton, Ontario, Canada
Elwell-Parker ESI500-36
Ottumwa, IA, United States
Harrisburg, SD, United States
Wentzville, MO, United States
