Code 2
serial number 71410. This truck is throwing code 2. I have replaced the 24" and 60" switches. I have ran the on board diagnostic tests ESY21 and ESY31. both switches test good. Code appears after truck start up completes. This is limiting travel speed to 1mph. Any help would be appreciated.
John
  • Posted 10 Feb 2015 06:00
  • By BREWSKI
no problem friend.
  • Posted 11 Feb 2015 22:53
  • By stam
You are correct. Found the problem in the wiring for the 150" switch. Wire was pulled out of connector at controller. Thanks for the help.
  • Posted 11 Feb 2015 08:57
  • By BREWSKI
there should be a 150" switch as well mounted to the top right of the mast. have a look
has someone been on this before you? sometimes jumpers are used when the 150" switch isn't used maybe your missing one?
some of the raymond ones have a switch on the bottom of the mast on the right side in front of the battery compartment, has given me grief before. this is just a raymond cheapie orderpicker branded toyota.
  • Posted 10 Feb 2015 07:09
  • Modified 10 Feb 2015 07:13 by poster
  • By stam
Evansville, IN, United States
Daleville, IN, United States
Uxbridge, Canada
St. Louis, MO, United States
Jeannette Walker Jeannette Walker
CEO, MHEDA
President, European Rental Association (ERA)
Chief marketing officer, JLT Mobile Computers
