Code 12833
Does anyone know what this code is 12833
Hope some one can help me
  • Posted 17 Mar 2021 10:01
  • By Low1964
  • joined 17 Mar'21 - 4 messages
Low1964
Thanks a million I found the TPC on the line contacter broken (terminal) put a new ring terminal on it test unit all will so for
  • Posted 19 Mar 2021 06:33
  • By Low1964
Low1964
Verify battery voltage and fluid level. Check all cable connections at controller and motor. Code is for DC Buss Low. Do not fill battery to top of cell. Only cover the cell membrane that you can see with cap removed. When checking cable connections, disconnect battery so you do not short anything out including yourself. Best to get your local dealer involved. Good Luck
  • Posted 19 Mar 2021 06:06
  • By Fishmech
  • Virginia, United States
Mitsubishi FGE35AT
Ice 28INCH-AUTO-SCRUBBER
USD8,350
