code 11
Code indicates depressed accelerator pedal ( I think ), Customer found and removed cracked micro switch a pedal. I installed new switch and adjusted. The unit worked fine for 10 min then same code. Switch checkes out ok.
Any ideas
Thanks Ted
  • Posted 10 Aug 2012 23:57
  • By BrewCrew
We`re here for a good time
back to the basics.
1 key up truck and check the voltage at the distribution board CA 205-3 (should be 0 volts)
2 check voltage at both the master and slave controller. CA 401-3 and CA403-3 if you have over 18 volts then the calibrate the ACC and brake pot you need a handset and manual to do this. It's the regular handset used on all EV 100 systems.
  • Posted 6 Apr 2017 09:29
  • By Zerk
  • joined 21 Apr'16 - 28 messages
  • Arkansas, United States
trouble code says if you have less than 18 volts which I had zero on pin three on the connector at module and replace the module. I have 36 volts when the accelerator switch is depressed at pin 3 and 0 volts when it is not depressed.
how do you calibrate the accelerator pot?
  • Posted 5 Apr 2017 09:56
  • By BigAl88246
  • joined 5 Apr'17 - 11 messages
Calibrate acc pot and brake pot
  • Posted 7 Mar 2015 09:09
  • By troy_m
