clear codes K21 / K25
Can anyone explain how to clear codes on Komatsu or Nissan K21 - 25 engines w/out the hand set?
  • Posted 13 Jan 2012 19:38
  • By 7777
well proshade,
one thing that helps me with the 'pedal dance' routine is i watch the hourmeter flash, it appears to flash in 1 second intervals so if you use that as your timer to keep count you can hit it easier than if you were trying to watch a stopwatch or count in your head. :o)
meter on 1sec
meter off 1 sec
meter on 1 sec
this type of count
  • Posted 9 Mar 2012 08:09
  • Modified 9 Mar 2012 08:11 by poster
  • By Jplayer
John Player Jr
_________________
LiftOne, LLC
Charlotte, NC
Email: jplayer@liftone.net
Best time for that is if you have a coil pack down and must travel for a new one it sure beats the pedal dance or dragging out the laptop. You might have a reason to do the 4 hour thing or like me just cant muster the pedal dance.
  • Posted 8 Mar 2012 23:03
  • By proshadetree
  • joined 23 Feb'06 - 484 messages
  • Tennessee, United States
agree with JP on the 4 hours,am lucky the operator(s) will let me have the truck to PM it or leave me alone long enough to fix it without asking 20 times if its fixed yet,let alone let it sit for 4 hours just to clear a code....if it starts,runs and moves and lifts/lowers its good enough for them.....
  • Posted 8 Mar 2012 10:21
  • By kevin_t
pedal dance?
ummm we call it the 'hokey pokey' method for clearing codes
but it looks exactly like the same way we can do it on our trucks
yes its a pain in the butt to get it the first time but once you successfully do it its not so bad.
And yes there are a couple of codes this method will not clear and you do need the laptop to do it.
cough... cough...
unhooking the battery for 4hrs?
who has time to wait for that? not i
>rolls eyes<
:oP
  • Posted 8 Mar 2012 10:18
  • By Jplayer
John Player Jr
_________________
LiftOne, LLC
Charlotte, NC
Could revert back to unhooking the battery for 4 hrs.
  • Posted 8 Mar 2012 09:08
  • By proshadetree
Ed
I did put it in the message i sent? But in the meantime I updated my Profile. Thanks
  • Posted 8 Mar 2012 06:08
  • By james_b
  • joined 15 Oct'08 - 13 messages
Original post deleted...
Forkliftaction does not condone the selling or trading of propriety information including authorization codes or any other dealing of copyrighted material by unauthorised persons. Any correspondence about illegal activities on our forums could put you in breach. Forkliftaction would be obligated to pass your contact details to police authorities if they were requested.
Please do not post these types of material on our forums again.
  • Posted 6 Mar 2012 21:08
  • Modified 6 Mar 2012 21:11 by poster
Ummm......follow the directions in "the pedal dance" posted and codes will clear
  • Posted 6 Mar 2012 08:24
  • By kevin_t
Hello
can some one please email me the process to clear these codes?? bhdjim at yahoo dot com Thank you
  • Posted 6 Mar 2012 06:13
  • By james_b
"The Pedal Dance"
Turn the ignition switch on with accel. pedal released,after 3 seconds fully depress the accel pedal 5 times within 5 seconds(end in released position). After 7 seconds(timing is very important...1 mississippi 2 mississippi etc....) press and hold down accel pedal for approximately 10 seconds(again timing) until the hour meter starts blinking, release pedal and push down and hold again for 10 seconds) hour meter should be on with no codes showing,shut key off and test to see if codes cleared.
  • Posted 13 Jan 2012 20:28
  • By kevin_t
Muncie, IN, United States
