clark TMX20 zapi fault codes
Looking for some help with fault code 079.
a/c lift, double E rated. no travel.
TMX25-0000-9597
thank you in advance for your help.
  • Posted 1 Jul 2011 05:03
  • By buzzurd40
  • joined 1 Jul'11 - 4 messages
thanks makes me think diagnosis of battery issue is right
  • Posted 13 Aug 2014 23:14
  • By grant89
  • joined 2 Jul'09 - 28 messages
  • Minnesota, United States
SHOP- REPLACED TRANS SELECT SWITCH
EVALUATED TRUCK SENT BATTERY FOR EVAL
AND BATTERY CABLES WERE REPLACED
REINSTALLED BATTERY PERFORMED
OPERATIONAL CHECK AND RETURNED UNIT BACK.
  • Posted 13 Aug 2014 23:05
  • By buzzurd40
Seat switch is wired out think I found the problem in the battery the one we used for testing purposes was junk plugged in a good battery and it seems to operate fine. This truck has been a pain due to some "Genius" cutting the main wiring harness to the controllers had to rewire and that was the last piece of the puzzle
Some people should not be allowed to have tools
  • Posted 13 Aug 2014 22:42
  • By grant89
Check your seat switch.....
  • Posted 13 Aug 2014 07:02
  • By kevin_t
Did you ever find out what was causing this code have the same issue in a tmx 20 if you fully depress the accelerator it drops out and code -079 kicks in
  • Posted 13 Aug 2014 06:48
  • By grant89
Taylor TX330S
USD159,500
Nagano NUZ090D
edition #1285 - 11 June 2026
