Check engine light on
Good day all, I have a Yale cushion tire 4.3 Jimmy propane with a diagnostic code and a check engine light. Does anyone know this code? 100-2 removing the battery cable did not clear it seems to start and run fine
  • Posted 21 Nov 2024 04:11
  • By Caleb_Harrison
  • joined 21 Nov'24 - 1 message
  • Oregon, United States
C Harrison
DTC 100-2 - Engine Oil Pressure OORH at Stall, Go to Cause D
D. SENSOR SIGNAL SHORTED TO BATTERY
CAUSE D - SENSOR SIGNAL SHORTED TO BATTERY
PROCEDURE OR ACTION:
1. Ensure truck power is OFF.
2. Disconnect the indicated connectors at sensor and VSM or applicable ECU.
3. Change DMM to volts scale.
4. At the sensor harness connector, measure the voltage across the sensor signal wire (+) and the negative (-)
terminal of the battery.
Is voltage approximately system voltage?
YES: The signal wire is shorted to an unswitched battery source. Refer to the appropriate Diagrams and
Schematics manual, depending on lift truck model, for unswitched battery voltage sources. Locate and repair/replace shorted wire/connection. Refer to the appropriate Wire Harness Repair manual, depending on
lift truck model.
NO: Go to Step 5.
5. Turn truck power ON and repeat Step 3.
YES: The signal wire is shorted to a switched battery source.Refer to the appropriate Diagrams and Schematics manual, depending on lift truck model, for switched battery voltage sources. Repair or replace shorted
wire.Refer to the appropriate Wire Harness Repair manual, depending on lift truck model.
  • Posted 23 Nov 2024 06:56
  • By Zoomlifts
  • joined 17 May'19 - 13 messages
Zoom Lifts
Crown RD572513TT6860R
Maxlion MTF30-45-2WD
