hello
I have a TCM forklift £¬charging pump 12N53-80321, FD20-30T3 leaking , The oil drips out at about 1 second intervals at idle and almost stops when the engine is revved.
custmer said that caused by a pin hole , but as far as i know , if indeed as pin hole , the symptom is not like above..do you know why?
thank you so much !!!
v.youku.com/v_show/id_XMzkwMjY0NTEy.html
Hi , youtube can't be opened in China , i dont know why , neither facebook..
the video posted on youku
http://v.youku.com/v_show/id_XMzkwMjY0NTEy.html
thank you
if on suction side, you have less dripping when rpm increases (and air foam in the reservoir tank) drips a minute do not matter much.
You would have to post it on youtube and give to link address.
I have a video , but how to post on this website ?
THX for your reply.
our person told me that if pin hole , the symptom should be oil drips out at about 1 second intervals at revved and almost stops when the engine is idle. isnt it ?
if the 'pin hole' is on the suction side, then the symptoms you mention are correct.
