Charging issue
When I plug the charger in the battery voltage jumps to 31-32vdc then it stops charging and light turns solid green. Batteries are all 6.19-6.21vdc. Voltage drop when lifting is 1vdc. I am assuming that the charger is bad?
  • Posted 1 Mar 2024 09:36
  • By Liftech
  • joined 1 Mar'24 - 4 messages
  • Wisconsin, United States
Rd
It is a 24v walkie with an onboard charger.
  • Posted 4 Mar 2024 01:34
  • By Liftech
Rd
What is the machine voltage calling for?..24 or 36?...something is off for sure but if batteries test good..could just be charger algorithm
  • Posted 3 Mar 2024 18:08
  • By Matthew_Reed
  • joined 12 Jun'23 - 113 messages
