Changing a Cell in a Battery??
Hello, We have a Battery with a bad cell. We are in the process of removing it.
My question is this.......is there a tool we can buy or make to grab the cell and remove it???Thanks
  • Posted 18 Apr 2009 06:17
  • Discussion started by Prentice
Just finished the charge this morning.All cells test O.K. once we freed up the cell it was out like **** threw a goose. Looks and works great.
  • Posted 24 Apr 2009 22:49
  • Reply by Prentice
Thanks for the great advice. We started to pull out the cell and it looks as if it has melted to the other cells around it..........not fun.......I might try and put a thin saw blade down the side of it but i am afraid it might damage the good cells.......i love these easy 2 minute fixes that turn out to cost ME time and money LOL. Again thanks for the advise we will put it to good use.
  • Posted 18 Apr 2009 23:42
  • Reply by Prentice
I'm assuming it a burn on battery strap then and not a bolt on one?
Welded battery straps, unless you have the proper tool to grab a thimble DO NOT CUT THE STRAP ON THE CELL YOU WANNA TAKE OUT!!
I just usually use a post drill and drill off the welded strap on the cell next to the one your taking out, bend up the welded strap then do the same again on the other side of the cell, now your left with your faulty cell you wanna lift out with two welded on straps still welded to it with holes in where you've just ran your post drill through. Get something non-conductive to fit nicely inside the two drilled out holes on the straps, I've got piece of hard plastic bar about 5" long by about 5/8th thick, get a small block n tackle if it's a stubborn little fella and attach it to your overhead guard and the other end onto your cell, yeh-ho, once it moves it'll be a breeze.
Bolt to bolt ones, simple. Run an 10mm lifting eye into each post and repeat as above, couldn't be easier.
Oh, and if your gonna weld on a new strap make sure the battery is well vented, that it hasn't been on charge recently and just start of with maybe 4-6volts then work your way up to 8 volts if your carbon rod isn't getting hot enough - easy!!
GOGGLES!!!!!!!!
  • Posted 18 Apr 2009 08:11
  • Reply by FLTdotCOdotUK
  • Tyne & Wear, United Kingdom
Wentzville, MO, United States
Ottumwa, IA, United States
Harrisburg, SD, United States
edition #1235 - 19 June 2025
