Cesab 150 - Fault 28 and slow lift
Can anyone please help with this fault - machine has fault 28 - ( steer sensor KO - we have changed the sensor but are unable to "reset" - we have a programmer for the AC2 control units fitted but don't have access to steer table - we have noticed a control unit mounted under floor plate - no 2833010 is this for steering or the DC-DC converter ? all help gratefully received - please email - service at mantonhire dot com thank you all
  • Posted 22 Jan 2015 20:17
  • Discussion started by Reddog
  • Wrexham, United Kingdom
Showing items 1 - 15 of 18 results.
Hello, could you please send me the pdf also, i have the same problem.
steering unit could rotate 360 degrees, little plat on the big ring gear wheel was broken, potentiometer is damaged to.
fixed this, but can't calibrate the steering pot.
info @ gevo-machinery dot com
Gevo Machinery B.V.
Hello,
I'm having the same problem with the BT C3E150 forklift. It's similar to Cesab.
customer has pressed buttons and entered calibration. This caused the steering potentiometer to become defective.
Replace the steering potentiometer, turn it 5 times to the right against the stop and then 5 times counterclockwise to get to the middle. I then have 2.5 Kohm. The steering wheel can also be rotated 360 degrees, so when do I know how it is properly positioned clockwise and counterclockwise with calibration? This means I cannot pass the calibration.
Could you send me the manual te set up calibration in dashboard?
Thank you!
Gevo Machinery B.V.
some kind soul sent me the manual to set up on dash display - if you can provide your email I will send you a copy over but it is all in english
  • Posted 13 Feb 2015 03:08
  • Reply by Reddog
how did you sort it, as i have the same problem
thanks already
  • Posted 13 Feb 2015 01:22
  • Reply by snellestinus
  • Antwerp, Belgium
Cesab all sorted now - thanks to everyone who contributed to this thread.
  • Posted 26 Jan 2015 21:35
  • Reply by Reddog
Hi, I just talked to a friend who works at Cesab. Hence, the 2 controls Zapi AC2 you see are both for traction, and control the traction motors, 2 while the electronic Panel that is mounted below pump control is ilo.
On the metal part of the electronic Panel where I fixed 2 AC2 you should have printed a M e a S, which stands for traction control traction control Master and Slave.
By logging in to the control Master drive you should be able to make your calibrations.
Send you by email the AC2 control manual and the manual of the PlayStation Zapi.
  • Posted 23 Jan 2015 23:19
  • Reply by mirko_c
  • Reggio Emilia, Italy
Good Morning Mirko c - the machine is fitted with two AC2 units I guess one is hyd service and the other will be for drive as with the earlier Blitz 315 we look after ? ( all be it different model units ).
  • Posted 23 Jan 2015 19:09
  • Reply by Reddog
Thank you - will print off and attempt to sort our problems.
  • Posted 23 Jan 2015 19:03
  • Reply by Reddog
Sorry gentlemen, but I read all your answers with a translator to understand something. However the Zapi you okay, it remains to understand how to make the acquisition of the signal of steering angle potentiometer
A question, control Zapi AC2 is for a single phase motor, while the Cesab Blitz has 2 three-phase motors, if I am not mistaken.Sure that the control is the right one, or you're working on the pump control and not on that drive?
Check the converter template and let me know.
  • Posted 23 Jan 2015 08:46
  • Reply by mirko_c
Piotr b. Can you please explain me procedure with with Laptop?Thanks
  • Posted 23 Jan 2015 07:58
  • Reply by nemanja_k
  • serbia, Serbia
manual have in mail
  • Posted 23 Jan 2015 03:49
  • Reply by piotr_b
  • mazowieckie, Poland
could you please provide the procedure to set up from dash board ? - if you have it on a PDF file or other electronic version you could email it to me - service at mantonhire dot com - Thank you.
  • Posted 23 Jan 2015 02:46
  • Reply by Reddog
im think its possible in handset but i never used this
all i to do from dashboard or laptop
  • Posted 23 Jan 2015 02:38
  • Reply by piotr_b
Cesab Blitz 150 - CE311013 - ( 2007 Yr ) - Thanlk You.
Can I set the limits using the hand held programmer I mentioned earlier or will I need additional hardware ?
  • Posted 23 Jan 2015 02:33
  • Modified 23 Jan 2015 02:36 by poster
  • Reply by Reddog
what model cesab you have ?
Iff version 3 whele AC
28 STEER SENSOR KO - TRACTION LOGIC UNIT:
Battery voltage out of range
Condition for error detection
This alarm signals that the steering potentiometer is out of range. The fault concerns one of the followings conditions:
- the “SET STEER 0 pos” parameter (straight wheels programmation) is wrong (lower than “SET STEER MIN” or higher than “SET STEER MAX”).
- the steering potentiometer feedback signal is out of the parameters definite window (.“SET STEER MIN” and “SET STEER MAX”)
In the first situation repeat the direction potentiometer acquisition. In the second situation repeat the
  • Posted 23 Jan 2015 02:26
  • Modified 23 Jan 2015 02:32 by poster
  • Reply by piotr_b
Linde C4230TL5
Hangcha CBD15
China
USD1,600
