Serial #: AT29C00258
This engine uses a Throttle Pot. w/ mechanical linkage to the Gas pedal.
Engine starts fine, seems like it is revving approximately 800 rpm's at idle.
Step on the gas pedal, the revvs go up about 100 rpm's.
Transmission shifts ok.
There is a red colored light on the dashboard; exclamation point inside of a triangle.
It's the only warning light that is on.
The Accelerator Pot. needed to be recalibrated.
Thanks.
The 1st shift mechanic finished the repair.
I had the same issue years ago w/ a GC25K, this truck was equipped w/ a 12 pin ECU. I replaced the sensor and resolved the problem, p/n 91165-15800.
good luck
your truck equipped with joystick
when joystick malfunction then the exclamation point inside of a triangle coming to be red colored light on the dashboard
Send image to my email I can help you
