caterpilar Ep18kt
Hello
Please can somebody help me.
I have problem with this unit. When you give command to lift or other it turns the pump on, there is oil at hydraulic block but electromagnetic ventils do not relase the oil to cylinders.
Relays under jojsticks are ok.
Does somebody has schemes for kyb-a electronic at this model.
I would apreciate
Marko
  • Posted 2 Mar 2009 00:28
  • Discussion started by marko
  • Croatia
on display there is no any error number, second truck was ok untill few days before.
It sttoped by itself and there is no lifting, side shifting functions. Steering is normal, driving functions are normal. I am getting oil to hydraulic block under right leg, you can hear that electomotor and hydraulic pump is turning on while you give command on jojstick, but electromag ventils are not relasing oil.
But two fuses (i think 2,5 A) below jojstick box are dead. I think that this truck is with contactors hyd
thanks
  • Posted 2 Mar 2009 07:35
  • Reply by marko
  • Croatia
is there any history to this truck? did someone change the logics board?
how many contactors does this unit have, some of these trucks were built with contactor hydraulics and some were built with chopper hydraulics, and the controller must have the correct eeprom in the logics board.
no other codes?
  • Posted 2 Mar 2009 06:08
  • Reply by edward_t
edward
sorry it is ep20kt
year 2002
etb5a75741
48v
thanks
  • Posted 2 Mar 2009 05:59
  • Reply by marko
  • Croatia
marko, could you give a serial number?
  • Posted 2 Mar 2009 01:30
  • Reply by edward_t
Ottumwa, IA, United States
Wentzville, MO, United States
Harrisburg, SD, United States
Crown SX3030TT4250
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
VETTER Industrie GmbH
