Cat Model m40d Fault Code F 2?
The forklift works for a couple hours then it randomly displays a F 2 Error code, thus locking down the machine not allowing any use. Only temp fixes are turning on and off (sometimes doesnt work) and some times having to actually un plug cord and plug it back in. This fixes the problem for a short amount of time and the problem occurs again. What causes this?
  • Posted 25 Mar 2010 15:06
  • Discussion started by Gemini
  • Manitoba, Canada
sounds like a battery problem
check cells and links , check charger operation, or could be another bad connection on the truck causing a high resistance when alot of current is used
  • Posted 31 Mar 2010 06:01
  • Reply by robster
  • lanarkshire, United Kingdom
Jospeh E Creed Jospeh E Creed
CEO, Caterpillar Inc
Secretary general, European Rental Association
Chairman of the Board of Directors, UgoWork
