Cat Lift Trucks (& Caterpillar) GP25NM:
Cat / Mitsubishi with H21 - additional gas injector dont work
Hello. I have a problem with CAT GP20CN with H21 engine, same as in many different forklifts CAT, Mitsubishi and Nissan. Fuel = LPG, engine have full electronic with 2 injectors: main , and additional what must work when acceleration pedal going down.
In my machine this additional injector dont work and its still closed, engine intermit when accelerate becouse dont have enougth fuel. Injector (valve) is OK, work when we give +12V. It have 2 cables: white is mass, and green/yelow is signal from ECU. Cables to ECU are OK, but we dont have signal from ECU. Any fault codes. MAF sensor is replaced and still same. Acceleration pedal position sensor was check and it is OK too.
Where is a problem? What signal ECU need to open this valve?
  • Posted 19 Dec 2018 20:46
  • Modified 19 Dec 2018 20:51 by poster
  • Discussion started by kor1
  • Poland
edition #1228 - 1 May 2025
