Cat GP18N (2004) clear dash of fault code
Can some one let me know how to clear the dash fault code using the Throttle pedal, I have done it in the passed but can not find the info.
Thanks
  • Posted 26 Jun 2012 17:36
  • By nigel_p
  • joined 8 Jul'10 - 20 messages
  • Worcestershire, United Kingdom
Thanks!!
  • Posted 26 Jun 2012 21:34
  • By nigel_p
"The Pedal Dance"
Turn the ignition switch on with accel. pedal released,after 3 seconds fully depress the accel pedal 5 times within 5 seconds(end in released position). After 7 seconds(timing is very important...1 mississippi 2 mississippi etc....) press and hold down accel pedal for approximately 10 seconds(again timing) until the hour meter starts blinking, release pedal and push down and hold again for 10 seconds) hour meter should be on with no codes showing,shut key off and test to see if codes cleared.
  • Posted 26 Jun 2012 18:54
  • By kevin_t
