Cat EC30K SX controller
I have a Cat EC30K with the SX GE Drive controller. Today this drive controller exploded the top off it. Does anyone know why this would happen? and if I install a new controller will it explode again?
  • Posted 9 Feb 2006 16:08
  • By Dave_C
  • joined 3 Jan'05 - 19 messages
  • Arizona, United States
I have experienced capacitor failure with the sx's that could be traced back to a bad/poor battery.
Under regen, the battery was not able to filter the current enough, that caused the caps. to heat and then pop.
  • Posted 11 Feb 2006 02:48
  • By mike_n
  • Alberta, Canada
If it is an MC2 version you had previously ensure that you get the latest MC3 settings for the new part as this includes current limiting when the brake pedal is applied, along with some other improved protection features. I would suggest also asking about additional EMC protection for the machine as you have had a cap failure, which normally entails adding a capacitor to the keyswitch terminal. Although I can provide all details it is better you go through the local dealer you are purchasing the part from.
  • Posted 11 Feb 2006 00:45
  • By daniel_g
  • joined 13 Jan'06 - 83 messages
  • Flevoland, Netherlands
Thanks for the advise; I called our local Cat dealer. They told me the capacitor exploded; I ordered a new SX controller with the changes; they also didn't recommend the Promatch reman because of the proplems they have had.
  • Posted 10 Feb 2006 11:52
  • By Dave_C
There are a number of running changes that have been made to the SX controller and the EC30K in order to improve the system and would suggest that you spek to your local Cat Lift Trucks dealer for further advice.
  • Posted 10 Feb 2006 09:29
  • By daniel_g
Maxlion FDR45
Ncn 85TH
Ncn 85TH 2014
Maxlion FDR45
Ncn 85TH
Ncn 85TH 2014
